Need to know how to angle this face as indicated in the picture.
How did you create this model? If you used the constraints it would be just modifying the value to new ones?
Here’s a rough mock-up. Does this help?
Great example. Only one comment I would use rotate around axis for better parametrization ![]()
Thank you so much! That was very simple and did just what I needed. Pretty new to this so I appreciate the help.
