I just cant figure it out. How could i center this hollow cylinder in that building block?
Select the inside face of the hole and then Transform and Move/Rotate. Use the handles to move the hole or draw a guide first and use Translate
Hope this attached video helps. The easiest way to do this is to position the circle before subtracting for the hole.
- Create the cube
- Create a circle on one side
- Position it to the middle (make sure you have “Midpoint” turned on in your snapping guides)
- Select the face, and cut the hole
Here is a video:
