Hello, new here and on sharpr3d
How can i color a 2d drawing in the sketch to export for a k40 Laser
Thanks.
Shapr3D doesn’t have colors (at this time). To export a 2D object, it must be in the top view. Then export as a sketch in DXF format. If you are looking to etch images using colors for various power settings, then Shapr3D is likely not best for this purpose. I use CorelDRAW for my etching laser projects, you can export your Shapr3D sketches and import them into another program better suited for etching.
Thanks a lot.
Karl from Belgium
