Hello,
I would like to snap & lock two bodies so when i move one the other moves along with it, but i don’t want to union them because i lose the edges. see attached photo.
thank you
Yoav
At the moment we don’t have a setting for that. Can you help us understand why would you like to keep that edge?
This element will be manufactured from two bodies separately and I wound to show that in the model. Also to be able to include the welding lines (via fillet/chamfer).
Then you should not union them indeed. The best solution in this case would be to add them to a folder, and just select the folder when you want to move them together.
Ok. I will use this.
Do you think in the future there would be constraints options to the 3D modeling as well, similar to the sketches?
Yoav Orion
BM Orion Ltd.
+972 (52) 3568232
yoav@bmorion.com
Yes, we will have assemblies in the future.
Can’t wait
