How to create a bowed or barrel-shaped ring profile?
I’m new to Shapr3D and working on a simple rotationally symmetric band form.
I began with two concentric circles, extruded them into a ring, and added fillets. The current cross-section is essentially straight:
I would like both the inner and outer walls to have a gentle matching bow:
I’m not trying to increase the edge fillets. I want the middle of both walls to curve outward slightly while maintaining a fairly consistent wall thickness. In the attached image, the YELLOW LINES indicate the desired broad bow of the inner and outer walls. I am not trying to increase the edge fillets.
Is the best approach to rebuild the body from a closed side-profile sketch and use Revolve, or is there a reliable way to modify the existing extruded body?
If anyone has a generic example or practice file showing a bowed band, gasket, or similar revolved profile, I’d appreciate seeing the workflow.
Personally, I would just recreate it using the Revolve tool.
That worked! Thanks so much for the advice.
