How to create a closed Earring from this?
I would like to make an Earring which is closed at upper and at the lower side.
I have tried several was, but no good result.
Is there someone who can help me with this?
See the photo, to see wat I mean.33274E96-F8F9-4BDB-8C85-AE9F1B203240
Hi would you be able to include a pic on the final design idea (something that resembles it, or a hand-drawn sketch)?
Here are some pictures. The hand drawing is the one, i would like to make.
Thnx for your support!!7386D1C9-F4C6-4D98-AA71-C70341A3685E
And this one is my last trial.
523391B0-102B-4250-A9A0-799240CB7337
It looks to me that you should Rotate profiles that are more or less rounded but are the same height. It looks like 2 or 3 would make your sketch. Not sure how you would blend them together but then create a shell. Maybe cut with a slanted jagged body that provides your cutouts? May try to do this later…
On second thought, I would try to create a 3D ribbon which I would copy, Rotate and distort around the earring with the Transform tool.
Thank you tommyn, i’m gonna try this this week and will show you the results.
Greetz Cesarine
I think that this is what you meant? Because my english is not so well. I’m Dutch. But I am very thankfull, that you helped me with this.
I learn every time I am drawing. In the end I like to make jewelry with my printer. That’s why I try some basic forms.
Greets CesarineD4F2A205-2B2C-4235-B9F0-6272C3BE4B3B
Nice job! Glad to have helped…
