I am trying to design a roadbicycle handle bar. The challenge is the shape of the handle bar that goes from X axis to Y axis and to Z axis continuously. I couldn’t figure out a way to do this.
Anyone has any idea? Sweep, loft doesn’t work as these work only for sketches that lie on the same axis or plane.
Part - Road bike Handle Bar
Any help here would be greatly appreciated!
You want something like this? Lightweight fixie
In this case I used loft with a guidecurve.
Ohhh i see. Clever! Ok, now i get it. I will try to follow this technique. Really appreciate it! That was very helpful!
Thank you!
I generally use Sweep alone for handlebars or tubing. I rotate the arcs/curves on their pivot points to change the sweep direction in any axis needed.
I agree with @Stephen and generally use Sweep. Here’s a quick simple example of using it in 3D space.
