Hi, I hope someone can help me out with this.
The picture shows below is a sample. I want to do something like this.
As you can see the surface completely round shape.
I had tried many ways to project the pattern on this organic shapes body. but it fails.
(the pattern will change after project because of the weigh is different.)
looks like it only can be done on Geometric shapes like cude or square?
https://www.pinterest.com/pin/557742735116474564/
Doing what you want to do with organic shapes are not easy. Here is the result of my trying to taper a curved surface…on a curved surface.
And, here is how I did it using projected hex sketches on an interior curved surface.
