How to extrude
I am trying out Shapr3D, but I can’t seem to do the most basic of things like extrusion of a door on a wall. I create a wall and drew in the door, thus created 3 segments, when I extrude all three, they merged into one piece after the extrusion and I can’t select the door part to create the opening. I don’t understand, it works on you tube tutorials.???
Share a link to the tutorial.
I am just trying to do a simple wall with a door opening. In plan view, after I drew the wall, I drew the door. After I extrude the whole thing to create a solid wall, I was suppose to be able to extrude the door part by extruding it and create the opening. But when I created the wall, the wall became one solid piece and I could not find the door part anymore to extrude. The procedures works on all the tutorial I looked at, I wonder why it doesn’t work for me.
Well, sometimes after extruding shapr likes to hide things like your sketch. In the side panel click on the eye thing for the body that is the wall to hide it. See if that helps
Xdrakosha sent you a video. That should work for you.
Also keep in mind you can select the wall’s “face” and choose “sketch” and then draw a doorway and or window on it to extrude your holes into it after the wall has been extruded.
