How to fillet rectangle line
Hi! how can I fillet line rectangle easily? I want to make 10R coner
Should I trim after moving circle to the edge?
Typically, when you’re modeling solids, the quickest way is to extrude the rectangle and then do the fillet on the solid.
Yet, we are using Shapr3D because “all the other CAD programs” are inadequate…,
You have more control over fillets on the modeling side than you do on the sketching side.
Check out these fillets:
