How to Import a 3MF file back in to modify it
Hi I tried to import a 3mf file that I had saved, but nothing is in the working space. Is it possible to import my 3mf file so I can work with it further ?
3MF or STL formats are not editable models. You can only modify them by subtracting portions of them or adding objects. They are not direct modeling entities.
McD
Nevermind I figured it out :slight_smile: I had to first convert the 3mf file to STL format using a 3rd party free online converter, then the import of the STL worked perfectly
I just got the Bambu lab X1C with the AMS unit. Love it so far. Bambu has a new AI that can take a 2D single picture and convert it to a 3mf full 3D file. I wish I could import this file into Shapr3d as is even though I can only do limited editing on the file. Some files on thingiverse I can import into shapr3d. And do some simple edits.
open that 3mf in Bambu Studio and export it as STL.
Near the bottom select Export as on STL and you can import.
John
I have the Bambu X1C as well. I’ve not tried the AI tool yet, but is it’s only output 3MF?
McD
Procurement
Custom Karvings
29716 Avenida De Las Banderas
Suite B (Rear of building)
Rancho Santa Margarita, CA 92688
Procurement@CustomKarvings.com
(949) 702-3180
