Import, Export .3mf files
Hi all,
First when I post I have to delete all junk that explains how to post. Is there a way to turn this off so I don’t have to keep deleting all this text before I can post?
I see I can Export .3mf files but I still can not import .3mf files. My question is why has this feature not been add, yet? I was thinking of trying to export my full design into Bambu Studio, Simply my design, then import the full design back into a new project file in Shapr3D. I am not sure if I can do this as one project file. I probably can do this with .STL files one object at a time. But that would be nuts to expect me to waste that amount of time on a mundane task. These types of tasks is what I am trying to get away from. Especially in this age of AI.
This might not be a perfect solution but I found that exporting my files to Bambu Studio as described below actually works.
I selected and then exported all my parts in Shapr3d as one .3mf file.and copied it to the Files app on my m2 ipad pro. Then I copied the file to my m1 max mac. Then I imported the file in to Bambu studio as a new project. I then Split the file apart into the individual parts. Then I auto arranged the parts on multiple beds. Which Bambu Studio does well and automatically. Then I clicked on each part and selected simply. Then I selected the level of detail. From the slider. Then I selected all objects and exported as multiple STL files. Then I copied the files back to my ipad pro then I imported these into Shapr3d. I think I combined some of my objects into one file. This seems complicated and yes it could be simplified by having this function built into Shapr3D. So Far it seems to work. I have not tried to alter the parts to comment on that part. I will see how it goes. In Theory that should speed up Shapr3d. Shapr3d is getting bogged down with all the Triangles, etc. that it is slow to process and crashes all the time.
