How to make a lattice?
it been a while since I’ve used 3d Software, I’m looking to see shapr3D would be a good fit for our company before buying the pro version. but I’m struggling on the best way to add our diagonal bracers to our lattice tower.
I have the 3 cylindrical legs and need to add cylindrical bracers in a zig-zag pattern between each side.
Pattern tool should work. OR simply use the move tool in copy mode.
Do one set of braces between 2 legs, then select those braces and use the move tool to rotate copies to the other two sides of the leg triangular configuration.
are you able to advise on the best way to add bracer, I’m struggling to draw on the right point of the leg curve
Create a construction plane that passes through the center of the two legs, then sketch on it.
that helps thanks
Quick shot at this. I love this community.
Sketches on planes are key!
