How to morph two shapes together?
Is there a way to morph these two objects to have a seamless connection in between? Basically need one pipe to morph into two, three and four (for now just trying to figure out two)
View from the bottom:
Here is forum member PEC solution, I think it will help.
The difference is that you have to use a guided loft instead of a sweep tool.
Thank you!
