How to specify angle of linear pattern?
I know how to do linear patterns in my sketches, so long as i want the pattern to go left to right or up and down. How do i specify that I want things repeated along a specific angle?
I can’t rotate the view to a specific angle so that left-right / up-down are at the angle i want.
The best workaround I’ve come up with is to make the lines at the wrong angle, do a linear pattern, REMOVE the linear pattern constraint, but leave the products of its action, and then rotate them all as a group to the right angle.
This feels very Not Right™
Does this help?
a) holy crap.
b) I would have never thought of that
c) Yes! that’s a much more reasonable workaround. :bowing_woman: Thank you.
This is indeed a great tip for patterns in sketches. Can something similar be done when patterning a body?
Yes, exactly the same way. Sketch a line at the desired angle and align the center of the linear pattern gizmo to the angled sketch.
Thanks, that makes complete sense. The problem was that I was trying to modify an already-created pattern. The gizmo is only available when a pattern is initially created. When modifying an existing pattern, the gizmo doesn’t appear. This is not ideal. When modifying a pattern, one should be able to change the position of the gizmo.
After playing around with this, I noticed a couple of other undesirable behaviors. When I set the spacing between pattern elements, I expect that number to set the spacing between the elements, not the spacing between corresponding element faces.
The body in the video is a 0.75" x 3.5" board. I want the pattern spacing to be 0.5", i.e., I want each board to be 0.5" apart. To do this in Shapr3D, I have to set the spacing to 4" instead of the more intuitive 0.5". This also fails to convey design intent because if I later increase the board width to say, 5.5", I’d have to update the pattern spacing to 6" to maintain the desired 0.5" board spacing.
Lastly, when I create a pattern, the body automatically gets put into a folder named Linear Pattern xx. This is fine, but if the pattern is deleted, the folder remains. If I delete a pattern, the folder that was created as part of that pattern should also be deleted.
That is amazing, thank you
Thanks so much for this work around! Epic!
Not possible along a curve is it? That would be a feature request right?
Only with manual work. I mean, you can use some tricks to make it almost automatic, but depending on the task, it will still require some manual effort.
You can make a feature request for that, but you wouldn’t be the first. People have been asking for it for years.
As would be objects increasing and diminishing in scale, rotation and 3D arrays.
