How to tell if a sketch is fully defined?
For those of us that comes from using Solidworks, they have a feature where if your sketch is fully defined (the whole sketch is fully constrained and not movable), the lines of the sketch will turn black instead of blue color when the lines are not constrained. Are there similar indicators in Shapr3D so I can quickly identify which lines are missing constraints? I found that with a fully constrained sketch, it’s easier to modify afterward when the 3D model doesn’t turn out the way you wanted without messing up the whole sketch.
Thanks!
Shapr doesn’t have fully defined constraints confirmation.
It was requested by others though.
Read below post.
