I believe that many friends have encountered the same problem in the recent versions, that is, the jamming and program crash during operation.
I use an M2 IPAD. When the design draft has a lot of content, it will jam and crash. Previously, it was solved a little by merging historical records, but it was found that it still could not be solved in the end. The jamming phenomenon still exists. In the past few days, I found that there are many invalid folders in the left project, up to thousands, and the names are all straight lines. They should be left over from the process. After all, I merged historical records in a process to ensure the process of operation.
But when I want to delete these invalid folders, I can only click to delete them one by one, and I can’t select and delete in batches. When the operation itself is jammed, facing thousands of contents, it is undoubtedly impossible to delete them. It may take several weeks to operate continuously. These folders are the source of jamming. I hope the official can solve this problem in the latest version. Attached is the operation video, invalid folder screenshots and project files.
Designs larger than 30MB cannot be sent…
First I would export as shapr3d for backup.
You can try to merge all modeling steps in the history panel.
AND OR
Export it to Parasolid so you can import back back just the 3d MODEL.
The steps will delete empty folders and sketches.
Hi, Could you please send us the .shapr file on the support portal?
We’d like to investigate.
---- Replied Message ----
From | Lys via Shapr3D Communitynotifications@shapr3d.discoursemail.com |
Date | 12/19/2024 22:51 |
To | gugongmiaogugongmiao@163.com |
Subject | [Shapr3D Community] [Share your creations] If you experience lag during use, you can come in and take a look |
| Lys Shapr3D Staff
December 19 |
Just a quick reminder—we’re still waiting for you to share the .shapr file so we can take a closer look and help resolve the issue.
