Import of Polymesh solids from Rhino in Parasolid or STEP files
Im trying to import a solid into Shapr3d in STEP or Parasolid formats. I can import the solid successfully however i cannot subtract from the solid or do any boolean operations in shapr3d.
The workflow is as follows:
Export from Delftship (Hull Modelling Software) in IGES
Import into Rhino, Join all surfaces to create a CLOSED Parasolid. No naked edges.
Export from Rhino in either STEP or Parasolid x_t
Airdrop to my IPad Pro 2018 and import into Shapr3d.
The solid shape appears, it allows replace face however any boolean operations fail e.g subtract. I can successfully complete a union with the solid however nothing subtracting for some reason.
I did the exact same process (from Delftship to Shapr3d) with a simpler shape such as an open cube and it worked fine.
Many thanks for your assistance.
Kind regards,
Nick Lyons
+61412530144
As i am a new user i cannot upload the files.
I reported the same problem to the guys: here is the link:
Hi Nick,
would you be able to send the files to support@shapr3d.com, we will take a look at it.
Thanks for your patience
I’ve done a bit more investigation on this. When extruding a new solid, the program won’t subtract from the imported object. If I create a solid in shapr3d separately, then move the solid over the imported object and use the tools→subtract the subtraction will complete.
It appears there is an issue with the automatic Boolean subtraction when extruding solids into imported objects.
Another issue I found is that it doesn’t appear the imported object functions as a solid correctly. I cannot fillet or chamfer any edges.
Hope this helps.
Nick Lyons
Hi Daniel, any movement with this??? Its been 2 weeks now? Many thanks for your assistance.
Hi Nick - sorry about the wait. I’m aware we haven’t replied - please allow us a few more days.
Ok no worries, thanks for you help.
