I have some issues with the import/export of step files. You can see it on the pic above. What can i do to fix this problem? It is the same issue with exporting step files from Shapr3D and open it with Solidworks. Some of the surfaces are gone or glitching away.
If you could send the step file to support@shapr3d.com we would love to look into it. Otherwise it’s much better to export to Parasolid (X_T) format from SolidWorks when importing to Shapr. That is guaranteed to work flawlessly, as there is no data translation needed in that case, as it is the native format of both SolidWorks and Shapr3D.
Hi and thx for the fast reply. The export/import as a Parasolid file fixed the issues.
