While using the iPadOS 26 public beta, I have noticed that with the latest updates, I am unable to import a *.SHPR file into the iPad. The import function does not work either from the main menu or after creating a new project.
I have tested the same import process on both Windows and macOS computers, and it works without any issues on those platforms.
For clarification, this is an exported SHAPR file with defined variables.
I would appreciate any guidance or assistance you can provide regarding this matter.
“I am using an iPad Pro M4 with iPadOS 26 Public Beta 3
today I installed iPadOS 26 Public Beta 4 and I have noticed the following issue. When a file is stored on iCloud and I try to import it, the import does not work in any way. However, if the file is stored locally on the iPad, SHAPR imports and opens it without any problem.
At the moment, I need to manually copy the file from iCloud to the iPad’s local storage before I am able to import it.
