Hello,
can someone maybe help me, I accidently tapped around while scatching and now have a second IOC in the middle upper screen that can neither be tapped nor removed. It is just there and kinda annoying while constructing. Has someone an idea what to do?
Thank you very much
Hi!
If you restart the app, it should go away.
Thanks, but that did not help unfortunatly
Did you “force close” the app?
Sending it to the background doesn’t help.
Hi thank you so much for your answer, I will try that
