Is Sharp3D a parametric software?
Hello everyone.
I come from Freecad and in this software there is a powerful feature: a connection between a body and his sketch.
Supose that I draw a circle with 50 mm of diameter and extrude to a cylinder. Supose now that I change this diamter to 20 mm. In Freecad the chlinder body changes to 20 mm diameter automatically.
Is there no feature in Shapr3D?
Thank you very much.
In Shapr3D , we work with the bodies. You can tap the surface of the body and change its diameter directly.
Thank you.
Works perfectely. :grinning:
