Issue with Sketcher: Difficulty in Cloning and Symmetrical Alignment
Hello Shapr3D Team,
I am experiencing an issue with the Sketcher feature when trying to create patterns. Here are the details:
Description of the Issue:
When I create two circles inside a smaller circle using the pattern function, the circles appear as expected. However, when I attempt to draw other shapes in the same sketch, the cloning or copying function does not work correctly for symmetry or rotation at any degree angle. Instead, the offsets are often in the nanometer range, causing the shapes to not align with the construction references as intended.
Specific Problems:
  1. Non-Constructive Placement: The drawings end up in positions that are not aligned with the reference sketch, resulting in sketches appearing within sketches. The cloned shapes do not align correctly along the X or Y axes or rotate as anticipated.
  2. Alignment Issues: When I use the Align or Move/Rotate tools to position the shapes, they do not appear in the correct positions as per the cloned patterns. The alignment functions seem limited to left-right and up-down adjustments, which do not allow for true symmetrical mirroring from the selected center or lines.
Suggested Improvement:
I would like to suggest adding a simple function for symmetrical cloning or mirroring inside the Sketcher. This would greatly enhance the ability to clone any drawing easily within the Sketcher environment and allow for more efficient design work.
I appreciate your attention to this matter and look forward to any updates or solutions regarding this issue.
Thank you!
Best regards,
Update on Sketcher Pattern Function Issue - Solution Found!
Hi everyone,
I wanted to follow up on my previous post regarding the issues I encountered with the Sketcher feature, particularly with the pattern function. Here’s a quick recap of the problems I faced:
  • Creating Patterns: Initially, when I created two circles inside a smaller circle using the pattern function, the circles appeared as expected. However, when I tried to draw other shapes in the same sketch, the cloning and copying functions did not work correctly, leading to misalignment.
  • Non-Constructive Placement: The cloned shapes often ended up in positions that were not aligned with reference points, resulting in sketches appearing incorrectly relative to where they should be.
  • Alignment Issues: Attempts to align or rotate shapes often did not position them as anticipated, making true symmetrical arrangements quite difficult.
Suggested Improvements:
I mentioned the need for a feature that would allow for easier symmetrical cloning or mirroring within the Sketcher environment.
The Solution I Found:
After experimenting with different approaches, I discovered a workaround that, while not the simplest, has proven effective:
  1. Using Rotation for Construction: Before creating the pattern of circles, I first created a single circle and set it to 360 degrees of rotation for construction purposes. This provided more reference lines and points to understand where the elements are positioned within the sketch.
  2. Enhanced Reference Geometry: By using additional construction lines and points, I was able to create a clearer framework for placing shapes accurately. This has helped manage the alignment issues that I previously faced.
  3. Considering Resource Use: While this method works better, I did notice that it requires more computational resources due to the larger cloning pattern.
  4. Defining the Rotation Point: Looking ahead, it would be beneficial to have a feature that allows setting the pattern’s rotation point more intuitively, helping avoid excessive iterations (like 380 degrees) when generating patterns. While this workaround isn’t as streamlined as the ideal solution I suggested earlier, it has significantly improved my workflow. I hope this helps others encountering similar issues. If anyone has further suggestions or different methods to enhance pattern creation and alignment.
Positive Experience with Shapr3D – A Game Changer for CAD Users!
Hi everyone,
I just wanted to take a moment to share my overall positive experience with Shapr3D. After exploring and experimenting with the platform, I am genuinely impressed by how user-friendly and intuitive it is compared to other CAD software like SolidWorks, Creo, AutoCAD Mechanical, and others.
Highlights of Shapr3D:
  • Ease of Use: The workflow is incredibly smooth, making it easy for both beginners and experienced users to navigate the platform without feeling overwhelmed.
  • Intuitive Features: Many of the functions and features are designed to be intuitive, which allows for quick adoption and application. I appreciate how straightforward it is to create and modify designs.
  • Clean Interface: The interface is visually appealing and easy to understand, contributing to a more enjoyable design experience.
Suggestions for Improvement:
One suggestion I have is to consider implementing a right-click menu for quick access to additional functions and features. This could further streamline the workflow by providing more options at the user’s fingertips.
Overall, I find Shapr3D to be a very promising tool in the CAD space, and I look forward to seeing how it evolves in the future. If anyone else has had similar experiences or additional suggestions, I’d love to hear them!
Best regards,
