Issues tracing an .stl
I am trying to trace an .stl file of a 3D printer hot end to make an adapter for it. I’ve gotten most of it completed, but the heat block has some interesting geometry that I’m having an issue with. I know how to create the geometry, but when I try to trace the geometry with a spline, I am getting some odd behavior, and am wondering if this is a bug or I’m doing something wrong.
There are two issues that I’m experiencing…
  1. I’m not sure why the points and lines on the imported object are highlighted when I place a construction plane on a face of it. They are distracting and not helpful, because you can not edit the points, lines or faces of the imported .stl.
  2. When I try to trace the lines of the imported object with the fit spline tool, as soon as I draw the first segment and lift the pencil, a full control point spline is placed on top of the line of the imported object. When I try to place the next segment of the spline, a new control point spline is placed on the previous one, but with a different alignment. This would be great if the spline it placed was aligned perfectly with the imported geometry, but it isn’t. Here’s a video of it…
I have also included the file I am working on for others to try and see if they are experiencing the same issue.
Mount v1 Copy.shapr (35.3 KB)
I checked out your file. First, the imported model is not an STL file. It is a solid body that cannot be edited within Shapr3D. If you want to trace as you intended, move the plane a short known distance from the surface then draw you spline.
As a test, I exported your file as an STL then imported the STL and placed it next to your imported body. The STL is a mesh file and selecting any one surface selects the entire mesh. Here it is.
HotBlock.shapr (154.5 KB)
Actually, no need to trace. Move the plane away and use the Project tool.
Sorry, it’s a .step file.
TigerMike…you are a monster! Thanks for this.
It’s still interesting that when trying to create the original spline, multiple ones are created. I’m still curious what causes that.
:tiger: Grrrrrrrrr
Hey @jcclow,
The spline you see appearing is the projection of the edge. As the control point you place has to be snapped to a sketch object, the edge is automatically projected.
