Issues with History version of Shapr3D
I forgot what the actual name given to this version so let me know. I found some issues. 1: I created a rectangle; extruded the rectangle 240mm to create a leg for a small stand for my 3D printer Main board box/case I am designing. I want to copy the first leg to create 3 more legs. Seems simple. I select the first leg. Then I tap on copy. I then drag the copy. So now I have 2 legs. Here is my issue in the other version of Shapr3D as long as “COPY” is still selected I can quickly and easily drag/copy 2 more legs. Done. Easy. Is there another better way to make simple multiple copies of an object. Or can we go back to the old way described above. Thank You
Also, if I try to drag a second copy it just moves the first copy. It does not creat a second or third copy. Even though it shows that the copy option is still selected.
