I work with decimal and architectural format when inputting dimensions in the same design. I like the keypad can do math for me but it would really help if I could enter in either decimal or architectural and have shapr3d convert to the desired output format whether it be decimal or architectural.
My main request after the rambling is to have the key pad accept a decimal or feet/in.
Thank you for any consideration given.
