Laggy on Desktop
As you can see - there should be no reason at all why Shapr shouldn’t be blisteringly fast. But it aint!
Yes, it should. We’ve fixed quite a few performance problems in the last few weeks, but apparently there is more work to do. Apologies for the inconvenience, we’ll fix it quickly.
Thanks. It actually worked pretty well for a while but then 2 updates ago it reverted, and the last update didn’t improve.
I’m also seeing performance issues. It starts out fine, but as I continue modelling it gets worse and worse (input lag primarily). I’m not making exceptionally complex geometry and my system should be more than up to snuff.
OS Name Microsoft Windows 11 Pro
Version 10.0.22631 Build 22631
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-7I7R4DI
System Manufacturer To Be Filled By O.E.M.
System Model B550 Phantom Gaming 4
System Type x64-based PC
System SKU To Be Filled By O.E.M.
Processor AMD Ryzen 9 5900X 12-Core Processor, 3701 Mhz, 12 Core(s), 24 Logical Processor(s)
BIOS Version/Date American Megatrends International, LLC. P2.40, 10/19/2022
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASRock
BaseBoard Product B550 Phantom Gaming 4
BaseBoard Version
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume3
Locale United States
Hardware Abstraction Layer Version = 10.0.22621.2506
User Name DESKTOP-7I7R4DI\vecto
Time Zone Central Daylight Time
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 19.8 GB
Total Virtual Memory 39.9 GB
Available Virtual Memory 24.1 GB
Page File Space 8.00 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Running
Virtualization-based security Required Security Properties
Virtualization-based security Available Security Properties Base Virtualization Support, Secure Boot, UEFI Code Readonly, SMM Security Mitigations 1.0, Mode Based Execution Control
Virtualization-based security Services Configured Hypervisor enforced Code Integrity
Virtualization-based security Services Running Hypervisor enforced Code Integrity
Name NVIDIA GeForce RTX 3080 Ti
PNP Device ID PCI\VEN_10DE&DEV_2208&SUBSYS_39673842&REV_A1\4&2283F625&0&0019
Adapter Type NVIDIA GeForce RTX 3080 Ti, NVIDIA compatible
Adapter Description NVIDIA GeForce RTX 3080 Ti
Adapter RAM (1,048,576) bytes
Installed Drivers C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_807bbbd5b556d8f2\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_807bbbd5b556d8f2\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_807bbbd5b556d8f2\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_807bbbd5b556d8f2\nvldumdx.dll
Driver Version 31.0.15.2737
INF File oem1.inf (Section071 section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1920 x 1080 x 119 hertz
Hi @vector010, thanks for the report. Could you also post the exact version number of Shapr3D? It’s available at the bottom of the Settings panel.
Version: 5.572.6640.0 #2b7df8db
I’ve noticed lag on Windows on keystrokes, specifically when entering numbers. This happens both on my multi-core laptop and my very high-end desktop. It’s very frustrating because digits are dropped. For example, if I enter “-32” sometimes the “-” is dropped. Sometimes just the last digit, so “2”, is dropped. Another example is holding the Shift key.. about half the time it’s not recognized so the view rotates instead of sliding left/right.
This all happens more often than not. It doesn’t seem like the UI is optimized for Windows users in regards to key events/handling.
I had the same problem a few months ago.
I deactivated one by one the widgets used.
So I found the one that was a problem.
In my case, it was Display Pilot 2 for my BenQ screen that Open at startup.
This provoked me big slowdowns on Shapr3D. It was impossible to use the app.
Since, it is very fluid, even with complex files with a well-filled history.
