Library of standard screw sizes
Do you have a library of standard DIN sized components? I’m specifically interested in screw sizes, but others may have interest in other standardised components.
@genie
Welcome to the Forum.
At present there in no such library, but it is understood that ‘a library’ is planned.
My workaround is to produce an External Thread of 10mm diameter on a Cylinder and and matching Internal Thread in a suitable Body.
Needed variations are derived from these by Scaling, e.g., 60% will give a 6mm Threaded object, and so on.
I have a ‘library’ of different Heads/Nuts/Specials/etc, across a wide range.
By selecting appropriate parts and assembling them in order it is easy to build the Fastening required. E.g., in the ScreenShot the 'stud can be made double ended by Copying and Moving.
I could really use that file. could i get a copy? New to the app but loving
it
Another option is to go over to McMaster-Carr’s website (McMaster.com), find a screw that matches your specifications, and download the STEP file.
awesome cheers, i always struggle with threads
Download 3D CAD Models for free | 3Dfindit also has many items with models
