Load a step file from github url
How can I load this file into shapr 3d?
https://raw.githubusercontent.com/hd-zero/hdzero-tooling/main/HDZeroGoggle-20220909.stp
This file opens in my browser, as one would expect. I’m not sure how to open it. When I try to import, I need to find a file saved locally and I don’t know how to do that. I’ve tried saving as a pdf, txt, web archive and none works.
If you right-click on the link and select Save Link As in Chrome, the entire file will be downloaded. Other browsers may call the option differently, but there should be an option like this.
