Loading the beta version?
If I load the beta version on windows, will I still be able to use the non-beta as well? will it load as a separate program? I"M working w/some mesh files w/the non beta as the beta wont run the same files on Ipad?
The two will be completely separate applications. You can manually export files from the live app and import them into the beta, but not the other way around, and they also won’t sync with each other. There’s one connection you might notice: they’re counted as part of the same device limit for an account, so you might need to log out from one to start using the other, but you can always continue your work after you log back in.
