Loft between two rings doesn’t create
Hi all,
I have a use case where I need to create a loft between two rings. Currently this doesn’t work. Is this a bug?
shapr3d_export.shapr (372 KB)
No, this is how lofting works. To achieve what you want, loft the inner parts then loft the outer parts, then subtract the inner part.
Got it, thanks Istvan!
Just a little context: it would be impossible to define this behavior in most of the cases, eg. what happens if one of the profiles have 2 holes, the other profiles just one, etc. This is why this is not done automatically.
Thanks for giving this context, this is really helpful!
What i do in these cases: I split both rings with a parallel line, then I loft 2 half rings and the other 2 half rings and than i add the bodies.
