Loft tool problems
I’m trying to make an organiser to fit inside a box. It is basically a series of thin wall boxes standing next to each other.
When I sketch out a base and and a corresponding upper end sketch I can loft what are essentially the spaces but it errors when I try to loft the adjacent walls.
What’s wrong? Why is the resulting object invalid especially why is it any more invalid than the area right next to it?
How do I get it to loft the walls?
Hey @Johnmartin,
Loft can only be used on solid sketches without openings. That’s why it doesn’t work on your hollow sketches, but here are two possible solutions for you. Hopefully it helps :wink:
Thanks. I can use those work arounds.
