Loft Experiment 2.shapr (217.2 KB)
I am having an issue with the loft from the main body to the front cap. Only half the loft is following the guide curve. Can anyone explain this and possibly provide me with a solution.
This is how I set up the guide lines. But on the top arc I still only get the arc surface on half the loft on the front cap. If you open body 4 you can see what I am referring to.
