I’m relatively new to this program. I created a design in shaper on my iPad but I can’t seem to find where they are even after searching every directory that I can see on the iPad. Anyone have an idea where they would go or a way to find them on the iPad? The only tutorial I could find shows how to use the windows file system, nothing about the iPad.
Your designs will not be stored on your Ipad unless you export it from Shapr3d to your ipad. Your designs will automaticly be stored in the cloud storage. If you are using the free the test version, you will not have these options. And I think you will only have one design available and no export. Witch means you will need to have all your drawings within one design.
Then use the isolate function actively to seperate your drawings…
