Lost my part
Hello just need help I made a newbie mistake I zoomed out to far and I can not find my part in the work space I don’t know if their is something to click it’s a relatively small part about 40mmX40mm and I just can’t find it please help!!!:thinking::thinking:
Just double tap on the 3d view cube. Should center it in the view. Upper left or right depending on how you set you interface up
Use fingers to zoom in to 5mm or 1mm, top corner should should show grid size above the view cube thingy. Then doubletapp the view cube
That worked thank you very much @Oregonerd :grin:
Welcome & welcome!
