Mac Mini Retro
Hello, here is my last creation. A Mac mini integrated with a Waveshare 5 inch IPS HDMI display.
instagram video
Hi, yes it’s very cool and the video too
how did you make the video with different views?
thank you
Thanks a lot!
I used a external keyboard and used the different shortcut keys for different views. I wish there would be shortcut keys for user defined views too.
Wow! The design! The Video! The print at the end! Well done!
ovation
Thank you!:pray:
OK for the views but how you animated and record ? Thanks
Hello, The first part of the video are just screen captures of the modeling view of Shapr3D. They are mounted with CapCut pro to achieve the appearing effect. Second part is done by recording the screen with record function of iPad OS and, with an external keyboard, use the “switch to xxx view” (more info here In the section navigation ). Both videos are mounted in CapCut pro and then I added the teaser view of the 3D printed prototype and the final message. Then it is just a question of finding a song that matches the movement and you are done.
Hope it helps!
Thanks a lot !
nice work, you should try making a sample :grin:
Thanks! By sample do you mean a real unit? At the end of the video you can see a teaser of the first functional prototype. I am preparing the final version right now, so you can expect more pics and videos soon.
Very cool! Love the use of a circular display.
Thanks a lot!
Adding pics of the final version
