macOS - Why Revit file association?
After installing Shapr3d on macOS, it somehow created an association with RVT (Revit) files. This is annoying as:
  1. It didn’t ask to make this association during installation and I don’t want to make this association
  2. Revit doesn’t run on macOS (I do have it installed in Parallels)
  3. Shapr3d cannot read the RVT file (AFAIK)
So I don’t understand why this file extension association was made in the first place…
That should not happen, we’ll look into it. Thanks for reporting the issue.
To fix it, Get Info on an RVT file, select Revit for the “Open with” application, and then click “Change All…”.
