Continuing the discussion from Model a Canoe? Lofting won’t do!:
Thanks for your feedback/suggestion. Your method worked quite well and is efficient. My first attempt failed at the bow of the canoe you can see both sets of sketches and the final result in the attached images. My attempt is based off how you would actually build a real canoe.
