I was trying to model a Canoe but was unable to make Lofting work effectively.
Any advice or suggestions?
I understand the concepts but have a hard time to realize how to create the curves/guide lines. I suppose they need to intersect the upper and lower surfaces. Could someone explain how to go about to create these?
The Shapr team has a lot of great tutorial videos on youtube/on the app. I would suggest watching the step-by-step guides, they helped me so much. You will start to see a pattern on how your design process should go, and how to resolve something if you ever get stuck.
As for Lofting/guidelines, the first 5 minutes of this video goes over it pretty well:
Thanks - This tutorial is exactly what I needed. I had understood how lofting worked but had a hard time to create proper connected guideline sketches.
The tutorial goes over this very well!
Graham
