Mass Properties Calculations
This feature would use the geometry and material densities specified by the user to calculate mass, cg, and moments of inertia of parts and an assembly.
This feature should allow me to enter material properties (specifically, density) for each component and it would then calculate the mass, cg, and moments of inertia of a selected part or a set of selected parts.
Calculation of the mass can be done manually using the total volume of the part and the material density. Calculation of the other mass properties is not practical.
This is a workflow blocker for me. To accomplish this, I must export a model to SolidWorks, specify all of the relevant information, and then allow SolidWorks to perform the calculation.
I agree with this request. Adding not only a center of gravity measurement tool, but also mass moments of inertia, and area moments of inertia would be really nice to have. As it is, I too have to export to another CAD like Solidworks to calculate these properties.
