Materials, weathering steel?
It seems like a long time ago that I requested Cortez as a material.
Is it possible that we could have it- there is no substitute that I can find in the materials samples, and its the only metal I actually need to show to others.
While we’re at it, might it be possible to edit the color of the available samples?
Thank you.
Corten, Not cortez, it was auto-corrected.
