Möbius Strip: There must be a better way to do this
@Bldt
Given existing limitations this is the cleanest/nearest I can get.
  1. The Profile was replicated at 15º intervals around a Circle longitudinally horizontal to the Plane.
  2. The 180º Twist was created by rotating appropriate Profiles by increments of 15º.
  3. The Loft ‘start-finish’ position was chosen in anticipation of the inevitable ‘join’ Profile(s).
  4. The chosen option was to Copy+Move, by 0.001mm, the Profile opposite to the Twist Centre Profile.
  5. An alternative would be to Loft up to the penultimate Profile to create Body 01 then Loft between faces to create Body 02.
  6. Cutting out a similar section of the Möbius and attempting to ‘bridge the gap’ was very problematic.
