Modeling advice
Hi guys,
I’m trying to make a piece of wrist armour with intricate detailing & I can’t for the life of me figure out how to best approach it…
This is what I’m trying to replicate:-
266C41C5-166A-4BD5-9D9D-E5560E50844F
And here’s where I am with it so far:-
24525C6E-5E18-4FBA-992B-E65EF33DE3FF 108E1748-B503-4A5E-83F8-28F2E5BB4F90
Due to the curved shape, it’s very difficult to get the rest of the detailing carved out. Is it possible to draw a flat piece like the following:-
5087A75A-4060-4169-B705-0EC1E83AFB43
… and extrude it a few mm, and then curve it after the details have been carved out? I don’t think this is possible, but had to ask…
Any other advice greatly appreciated,
Rob
No, unfortunately you can’t bend bodies :frowning: The way how you approached it is the best way to do it.
I have an idea for an approach that might work but don’t have the time right now to develop.
CE35A904-3AC0-4C40-9E98-08AABEB2343E
Basically project (Replace face) segments of the art onto the guard in a piece wise manner. You need to experiment with angle (20 degrees shown), number of steps, depth, etc. Hope this helps…
Thanks mate good idea that. I ended up creating a octagon inside the piece & extruded shapes from that to carve. It wasn’t the best idea as I was still using the translate/rotate to fine-tune some pieces.
Not my best work, but it’s not bad.
I guess I’ll go & print it now :slight_smile:
And the print. Came out pretty badly but I was experimenting with settings a bit…
0C604E0C-2576-4B0E-95F0-0A0B58ECD9E6
A guy in my 3D Printing Group prints this type of model flat in ABS and then dips it in hot water and wraps it around an arm-like mandrel FYI.
Wow interesting way to tackle the problem… I wonder if it’d work with PLA :thinking:
I can’t imagine using this method would keep the details flawless though…
