Is there a method to bend irregularly shaped flat plates?
I beg for someone to help me!!!
Shapr3D work with solid bodies. You can’t bend them because they are “solid”. But you can design them bended as you need.
P.S. If be honest there is a way you can deform body but it is too hard for most people to understand how to use it. You can use move tool on edges and you can make any edge on surface by projecting it.
Quick example
I will show a little bit later, when I come back from dog walk.
To make this kind of spiring you need to draw appropriate sketch.
First draw a spring using arc tool:
Then using previous spring as a guide draw wave-shaped line:
Next step is using offset tool and make a copy of previous form:
After that all you need is to extrude from sketch:
Dont forget to close the sketch loop before extrusion.
I sincerely appreciate your invaluable assistance.
Hi Xdrakosha,
How did you do the circles along the path ?
Arc tool and constraints.
one by one ? ![]()
Yes. Unfortunately we don’t have tool to make pattern by path yet.
Yes, sure.
Thanks.
