Modifying multiple extrude dimensions at the same time
Hi, I have multiple bodies that i would like to change extrude dimensions for depending on wood panel thickness for example. Is there a quick way to edit 20 bodies at a go instead of changing each body one at a time?
Hi @Alchemist ,
You can change multiple with offset face, but that will not change the extrude dimensions. Currently there is no way to change multiple extrude dimensions at the same time.
Variables are supposed to be coming this fall, which will address that issue.
