Moving from 2D to 3D in Sketch mode
I have difficulty moving from 2D to 3D mode while in sketch mode, I do this to visualise my extrude. I use a 3DConnexion space mouse and have to twist it up to 4 times before it moves out of 2D mode. See video. You’ll see my try to move the camera several times after creating the rectangle.
I would hope that we get instant move for faster workflow.
It slows me down.
Is this a workflow blocker for you? Is this why you can’t use Shapr3D for work? Is this slowing you down? Yes.
