I am working from my iPad. I have 100 Hexagons that I want to extrude onto a flat body that is 10mm thick. Essentially, I need 100 Hexagonal holes in the 10mm flat body.
The 100 hexagons are 30mm above the flat body and I need to select the bottom face of the hexagons to extrude and create the holes needed in the flat body.
Is there a may to mass-select the bottom face of the 100 hexagons at once, then perform the extrusion?
This is exactly what I was trying to do, but I discovered 2 problems.
You have to be sure that you are dragging your selection window across all of your bodies…you can’t select half of a body because it attempts to select the sides as a face. Must be a bug of sorts.
I was using the number “100” as a representation…I actually have 4000 of these, and when I attempt to do the Extrusion action…iPad crashes.
Thank you so much for the illustrations…very helpful.
