I have just a simple flat design with a couple of circles, and it is sized correctly as an SVG, shows up in inkscape as the right size, but when I export it as a DXF from inkscape the DXF is huge in shapr3D i tried both inches and MM import, seems like the same problem…
I also tried to import a sketch DXF and it does not show up or import it’s like missing, then I tried Sketchup as a 2d dxf, and that showed up but weird…
My SVG is a modified version of the same thing…
i tried to upload here would nto do it so i did a ticket…
