SVG - DXF - Shap3r
Im an amateur at designing CAD stuff, so I like to design drafts in Adobe Illustrator. I want to export SVG/PDF in mm and import them into Shap3r with the same scale/size. Online converters from SVG/PDF give me very weird results.
Is there a solution to this?
Thanks!
Ok sorry, Illustrator has a good DXF/DWG export via Export / Export As !
EOT
