Named "Breakpoints"/NoOps for Parametric Beta
History is great but renaming every step tideous, on bigger Project you normally have bigger chunks of work, like natural steps. So inserting a “named point” - without it doing anything, like eg “Handle finished” would help to structure the history.
Eg model a drawer. this consist of the body, the handle and the rails. probably I start with creating the body, then the rails and the handle. I’d like to have named spot in my history so I know where to set my breakpoint, if I late in the project to decide to change the body again.
Finding the right spot where to insert a new change in the middle of the history on first glance
It would be a big Quality of life improvement.
only other option I see is to have a concept of multiple objects, which all have their own history, and still can be seen in a single project. But that’s probably way more work, as basically adding a NoOp, which you can rename.
+1
I need also this feature to structure history.
